LEAKS WHEN IT RAINS
Old Jun 1, 2008 | 06:57 AM
hairyg's Avatar
Default LEAKS WHEN IT RAINS
Hello. I have a 91 740 sedan that leaks water through the slot of the brake pedal underneath the driver's side of the interior under the dashboard when it rains. How can I get to the leak and where do you suppose it is coming from? It has 78k miles on it. I don't see it happening when it is happening, however, I can clearly see white blue residue on the rubber of the slot. I have checked the drain hose on the firewall and it is clear. Could the problem be further up from that hose?
Thank you very much!
hairyg
Dec 23, 2011 02:25 PM
UMGuy423
Jun 22, 2011 09:27 AM
b26440510
Nov 10, 2009 07:52 AM
hairyg
May 25, 2008 11:10 AM
bdogfish
Nov 27, 2006 02:48 PM
