Lil help
Old Jan 20, 2009 | 05:22 PM
Adrenalin540's Avatar
Default Lil help
Sorry guys, I know this is going to sound ignorant, but where is the fuel pump on a 87 volvo 240 Located? I have the opportunity to pick up a car at a decent price and have a 'left over' fuel pump from another car (94 - 850) and wonder if the fuel pump goes in the same place and would it fit...
Thanks,
Opportunity to fix a dead volvo for practically nothing...
Old Jan 20, 2009 | 05:39 PM
Default RE: Lil help
The fuel pump is accessed from the trunk on the drives side. There is a square plate you will need to remove to get to the pump assembly.
Not sure if the 850 pump will work but you can try.
Old Jan 20, 2009 | 05:56 PM
Damn Tech, You are everywhere :-)
Do you know if the fuel pump relay is the same 103 and where is it located on a 240? I have a chance to pick up an 87 240 that the guy says needs a fuel pump for $500, but I will get him to $250...and I have a pump and relay ...if they fit...LOL
So on a 240 it is on the drivers side? I know on my 850 it is on the pass side...Where is the fuel pump relay located under the hood?
Old Jan 20, 2009 | 06:17 PM
Remove the carpeted panel under the dash on the passenger side. It is usually mounted on a bracket on the firewall. It is white and looks kind of like a double wide relay. Sometimes if the relay is bad you can resolder it and be fine.
Old Jan 21, 2009 | 03:47 AM
ok...thanks..I may get this car for a steal, and have 0 in it...for resale
Old Jan 21, 2009 | 07:43 AM
LOL good luck!!!!
Old Jan 21, 2009 | 10:18 AM
bubba240's Avatar
Remove the carpeted panel under the dash on the drivers side.
The relay is under the carpet on the passenger side. Two pumps - one in the tank, the other forward of the driver's rear tire.
Old Jan 21, 2009 | 10:28 AM
ORIGINAL: bubba240
Thanks for catching that I totally missed that I wrote the wrong side. I don't know what I was thinking when I wrote that. I guess my fingers were typing before my mind finished the thought!! LOL
I will edit it as well.
bluesb4sunrise
Jul 18, 2012 12:57 PM
Kool_J1
Feb 10, 2011 09:16 AM
95VO940Wagon
Oct 2, 2010 12:42 AM
garlendrix
Sep 10, 2010 09:01 AM
biffripjock
Mar 4, 2010 07:48 AM
