Looking to buy 1991 240. Anything to look for when buying???
Old Feb 25, 2009 | 07:18 PM
Srogers's Avatar
Default Looking to buy 1991 240. Anything to look for when buying???
Is there anything that is known to go wrong with theses? Things I should pay close attention to when test driving? Anything would help me out. Thank you!
Old Feb 25, 2009 | 07:41 PM
blue goose's Avatar
Not if it's been maintained right. How many miles? If it's been overheated sometimes the aluminum head will warp. It don't like too much heat. Other than that the engine is nearly indestructible. You can assume all the suspension bushings will need replacement but that's not a big deal. Watch for body rust, particularly around the windshield. What geographic location?
Old Feb 25, 2009 | 07:52 PM
TIPSP's Avatar
Got Boost?
When test driving it...push the car hard and see how it behaves. You should get a good Idea of what will be wrong after/during the test drive.
Old Feb 26, 2009 | 12:30 AM
Srogers's Avatar
Its in Peach Tree city. About 45 min south of Atlanta. 150,000miles. Would I be able to tell by looking at the block/head if it has been over heated?
Old Mar 1, 2009 | 12:12 PM
soundmiami's Avatar
I think 240s came from factory with 100,000 miles so that's not an issue, as far as chronic problems, where do I being???
I think any car starts to have issues after a few decades and 100,xxx miles, it's just the 240s mechanical systems are so robust,they outlast the electrical.
One problem is some electrical systems, unlike the mechanical parts which are visible, dependably can be an function of time, not use.
The short answer is, I would have reputable VOLVO shop look over the car first. Even if you're buying a beater, it would be worth the hour a shop may charge, and many will do it for free because they KNOW you're going to eventually need their services.
Good luck
Old Mar 3, 2009 | 09:16 PM
lukky4u's Avatar
these cars are reliable with general upkeep and maintenance. Just remember its not a sports car....things that i have found over the last yr with my 2 volvo 240 wagons are fuel pump relay, front suspension. nothing major. and this is with 250,000 miles. the other has 150,000 miles
sublimobile
Nov 19, 2020 01:14 PM
Scott150
1998-2000 model year V70
Feb 22, 2014 12:09 PM
Norcal
2001-2013 model year V70
Aug 26, 2013 06:34 PM
alecbh
Nov 1, 2011 02:46 PM
KMac
Jun 27, 2005 07:11 PM
