loose harmonic balancer
Old Jun 1, 2007 | 07:24 PM
bli745's Avatar
Default loose harmonic balancer
Weirdness. Locator Key sheared and bolt holding HB spun until bolt was almost out. No electric or PS.
Looks like I need a new HB because it took a beating. Last timearea was touched was 50K ago with
a timing belt job. Has this ever happened to anyone else? Edges of crank shaft got rounded off a bit, am i a goner?
Old Jun 2, 2007 | 09:56 PM
tedv's Avatar
Default RE: loose harmonic balancer
Had this problem with a BMW... Fixed it byfashioning a new key with ascrewand JB Weld. It did work. However, I can't say for how long since I got rid of the car- quickly!
Old Jun 3, 2007 | 09:12 AM
Best would be to do the timing belt since it is time to do it anyways.
Buya new timing crank pulley the toothed one and replace. The key was part of that pulley.
Pretty common for people that either don't get the outer pulley lined up correctly or don't get the crank bolt tight enough.
Old Jun 4, 2007 | 06:05 PM
bli745's Avatar
So the only thing that keeps HB in sinc with crank is the little nub on the cast crank gear? There is no seperate metal key for the slot in the crank shaft?
Ifso, no wonder the importance of proper bolt tightening. I bet the last mech didn't follow proper proceduresand, yes the belt will be replaced -the crank washer appeared to be backward and shaved off the belts edge by atleast an eighth inch. Thanks again,tech.
Old Jun 4, 2007 | 06:11 PM
Yes you are right on the gear.
Sounds like you go it under control.
Your welcome anytime.
dtom4
Jul 15, 2020 09:44 AM
TS88740GL
Mar 10, 2009 01:18 PM
lummert
Feb 22, 2008 04:45 PM
simeyrocks
Jan 26, 2008 09:02 AM
RocknTommy
Jul 22, 2005 09:44 PM
