Loose wire not connected engine bay
Old May 16, 2017 | 09:37 PM
Volvo240needshelp's Avatar
Default Loose wire not connected engine bay
See attached photos, unable to determine what this wire is for? The wire does have power running through it. The wire was hanging down against the firewall. This is for a 1988 244 DL.
Attached Thumbnails Loose wire not connected engine bay-20170516_190608.jpg   Loose wire not connected engine bay-20170516_190620.jpg   Loose wire not connected engine bay-20170516_190602.jpg
Old Jul 6, 2017 | 12:06 AM
Sambar Stag's Avatar
Needshelp, that wire is one of two that go to your a/c compressor. It is supposed to run underneath all that intake stuff and connect to a female connector in a plastic jacket clip that has the same green color. There is also a black wire connector near there also; check to see if that one is hooked up. I gather that your a/c doesn't work; if it does, someone ran a bypass circuit around it.
daviddudleyca
Jul 2, 2014 12:11 AM
enigmis
May 11, 2014 11:32 PM
Rickford
Feb 17, 2013 04:41 PM
jdpuyear
Nov 11, 2012 01:22 AM
VTBricked
Jul 19, 2012 06:12 PM
