losing water!
Old Sep 26, 2004 | 07:17 PM
vincent740t's Avatar
Default losing water!
Hello,
I recently purchased a 1991 740 turbo since i replaced the heater hoses and the radiator. I am still losing water with no apparent leak. I can smell antifreeze when I drive the car. However, I restricted the overflow hose and upon doing so the water started seeping from the bottom of the resorvoir and underneath on the passenger. If you stand t the right of the car right at the crease of the door hinge that's where it is leaking from. lo i've replaced the resevoir and cap.
Please help!
Old Sep 27, 2004 | 11:48 AM
Default RE: losing water!
Look under the car and see if it is coming out of the frame rail or coming off the transmission.Did you replaced the hoses from the heater core to the engine?If not check those.Did you replaced the hoses to the turbo if they have them? Another possibility also could be the heater core.Check these and let me know.
s70_007
Dec 19, 2008 09:26 AM
flapper
Oct 22, 2007 05:56 PM
paul
Jan 4, 2006 07:04 PM
blase
Jul 29, 2005 01:03 AM
mozhan
Dec 1, 2004 06:38 PM
