Low temp after ac retrofit
Old Apr 27, 2010 | 09:57 PM
escobar's Avatar
Default Low temp after ac retrofit
89 volvo 240 had an ac retrofit today at a non volvo shop. Drove it around for about 30 minutes and the temp gauge is running low. Thought it was a stuck thermostat, so I changed it. No help, still running low. The fan is running all the time. Any connection with the retrofit? Any ideas?
Thanks for your help.
Old Apr 28, 2010 | 02:50 PM
swiftjustice44's Avatar
Here in Texas, I typically wire the auxillary fan to the cmpressor so that it runs whenever the compressor runs. The stock Volvo radiator sensor in the radiator has such a high threshold before it kicks on that it is nearly worthless. If you were running the a/c and the fan was running non stop, this could explain your issue. Was it reading cooler w/o the a/c running? The average temp gauge reading on later 240's is the 9 o'clock position. Where was/is yors?
Another explanation could be the shop did a thorough job and cleaned the condensor fins of 20 years worth of stuff. I guess it all depends on where your temp gauge was before and now.
Old Apr 28, 2010 | 05:52 PM
escobar's Avatar
When I took it to the shop before the retrofit, it was at 9 o'clock steady, no issues.
With the ac off, **** turned all the way counterclockwise and blower off, as well as the ac turned on, it's at about 7 o'clock. Just ordered another tstat.
I'll go back to the shop tomorrow and ask if they wired the fan to the compressor. Thanks!
Gorm
May 6, 2008 02:16 AM
bauhaus
Nov 9, 2007 10:06 PM
elderzap
Nov 7, 2007 04:58 PM
douglasdsmith
May 1, 2006 04:01 AM
copurnikus
Oct 17, 2005 10:24 PM
