Bi-Xenon retrofit
Old Feb 27, 2006 | 07:44 PM
douglasdsmith's Avatar
Default Bi-Xenon retrofit
Does anyone know if a 960 can be retrofited with Bi-Xenon headlights?
Old Apr 6, 2006 | 01:27 AM
Ihatespeedbumps's Avatar
Default RE: Bi-Xenon retrofit
It's possible to retro fit almost anything. Some great resources are:
www.HIDplanet.com
www.xenondepot.com
Check their forums. I think one of those sites will retro fit for a fee. I'm not sure. You may try a quick google query.
Old Apr 6, 2006 | 01:09 PM
Thanks. These sites look like they have the needed information
Anyone have personal experience?
Old Apr 14, 2006 | 12:37 AM
I haven't tried yet, but my 940 is begging for a retro fit and I'm trying to get the ball rolling on it.
Old Apr 25, 2006 | 02:16 AM
Well they are installed on the low beams. So far so good, but there sure are a lot of extra wires lieing around to be coiled up. I may go in and shorten the wires that run from the ballast to the battery when I have an opportunity. In addition the bulbs show up any defects in aiming of the headlights very clearly.
I have not decided whether I will also do the high beams.
Old Apr 25, 2006 | 02:49 PM
One issue- The bulb failure light is now on so I need to find and pull the wire from the headlight sensor relay that goes to that bulb.
Should be a small job
Old Apr 30, 2006 | 12:42 AM
ORIGINAL: douglasdsmith
Did you retrofit in projectors or just a plug and play HID kit? From I understand, to get the bulb failure message to go away you have to fit the factory wiring with some resistor to "trick" the circuit into thinking the factory halogen is still installed. I have seen it on this forum, a quick search should yeild the results you are looking for. Also check, HIDplanet.com I think they have some info on the volvo HID setup thing.
Old May 1, 2006 | 04:01 AM
tupapison's Avatar
If you are asking if you can put HID lights in your car then yes you can, I did it with my 1995 940, and they look awesome!! i got the HID conversion kit for $280(installed), The bulb type is 9004
sebpop
Sep 30, 2008 06:01 AM
rickrarey
Aug 20, 2008 01:17 PM
Gorm
May 6, 2008 02:16 AM
bauhaus
Nov 9, 2007 10:06 PM
copurnikus
Oct 17, 2005 10:24 PM
