mechanic reports
Old Sep 15, 2025 | 12:45 PM
matdeinn3's Avatar
Default mechanic reports
Hello,
We have a 1983 Volvo 240 DL wagon that recently developed a problem starting. It would have to turn over a long time before it would get going. Two weeks ago, while it was idling at an intersection, it stalled and would not restart.
The local mechanic thought the most likely cause was a fuel supply issue, and we have now replaced the following parts without any improvement:
Fuel pump
Fuel sending unit
Fuel filter
Relays for the fuel injection system
Spark plugs
The mechanic reports that the car has spark and excellent fuel pressure, so it's hard to imagine why it won't start.
If anyone has encountered a similar problem or has suggestions about things we can investigate next, I would be very grateful for the advice. Compared to more modern cars with lots of electronic modules, one would hope that there are a limited number of potential causes for this continuing problem, now that we already have replaced the suspected problem parts.
Thanks,
Old Sep 25, 2025 | 10:02 AM
rallsg1's Avatar
Vacuum leaks could be a culprit. I once had a vacuum leak in my classic beetle which was intermittent. It would start right up, but at stop lights sometimes it would just stall, not being able to be restarted for two or three minutes sometimes. Turns out it was a vacuum hose plug that was holding vacuum sometimes, but not always. Check all your vacuum hoses!
matdeinn3
Oct 1, 2025 11:41 PM
TobyWoby
Apr 8, 2025 09:07 PM
pjpalmeri
Dec 6, 2023 04:04 PM
PSJV
Nov 13, 2023 06:45 AM
