Is my '92 940's o2 sensor bad?
Old Jun 20, 2008 | 09:08 AM
340mopar's Avatar
Default Is my '92 940's o2 sensor bad?
Howdy everybody.
The Check Engine light came on this week in my '92 940. The car has 160k miles.
I checked the code and it is 2-1-2,Oxygen sensor signal missing or faulty Oxygen sensor.
I checked the readings on the O2 sensor with the engine at operating temperature and they varied between 0.026 and 1.261 volts.
Is my O2 sensor bad? The engine runs fine, except at idle. Theidle isn't as smooth as it was before the Check Engine light came on.
Thanks.
Old Jun 21, 2008 | 06:32 PM
Default RE: Is my '92 940's o2 sensor bad?
Did you clear the code?
Old Jun 21, 2008 | 11:23 PM
340mopar's Avatar
ORIGINAL: tech
I did once and it came right back.
Old Jun 21, 2008 | 11:24 PM
Do you have an exhaust leak or a vaccum leak?
The sweep is good on the sensor.
Maybe intake manifold gasket bad.
Old Jun 21, 2008 | 11:38 PM
340mopar's Avatar
ORIGINAL: tech
As a matter of fact, I noticed a slight leak at the manifold to exhaust pipe joint yesterday when I was testing the sensor. I tried tightening the nuts on the manifold and they were all plenty tight.
Old Jun 21, 2008 | 11:43 PM
They are kind of known to warp. You might need to double gasket the joint.
Old Jun 21, 2008 | 11:47 PM
340mopar's Avatar
ORIGINAL: tech
Would an exhaust leak cause the 2-1-2 code?
Old Jun 22, 2008 | 06:28 AM
Default RE: Is my '
That leak should be before the O2 so yes it will throw the code. But still check for an intake leak as well.
Old Jun 25, 2008 | 08:03 PM
340mopar's Avatar
Default RE: Is my '
ORIGINAL: tech
Update; I removed the exhaust pipe and, using a belt sander, smoothed the flange mating surface on the exhaust pipe. On the exhaust manifold I used a block with 80 grit sandpaper to clean that surface. I used a new gasket and high temperature sealant.
So far, the leak seems to be fixed. (fingers crossed)
I cleared the code. It hasn't come back.
Thanks.
that4wdwagon
Sep 1, 2014 03:39 PM
carolina, PR
Oct 17, 2011 05:14 PM
flippyflipz
Dec 2, 2008 01:52 PM
02VolvoS40
Feb 4, 2008 06:05 PM
