My volvo 244 1984 doesnt charge
Old Feb 9, 2018 | 07:40 AM
Linus13377's Avatar
Default My volvo 244 1984 doesnt charge
My volvo 244's battery light does NOT come on at any times. Starting and running. No light. Nothing, and it doesnt charge. What can it be? Help please
Old Feb 9, 2018 | 07:41 AM
Linus13377's Avatar
EDIT : I have changed the regulator too
Old Feb 9, 2018 | 03:15 PM
you pretty much need a volt meter to do any testing here.
first thing I'd check is key on, but engine NOT started, and check the voltage from the smaller D+ terminal on the alternator to ground... you should see a few volts there, but not the full battery voltage. if you do NOT see any volts there, then check the BATT bulb in the instrument panel, also check the ignition switch. if you see the full battery voltage at this pin, then I suspect the alternator itself has a fried diode board
Spyros
Jul 1, 2012 08:16 PM
Spyros
Jun 13, 2012 04:24 PM
Spyros
May 27, 2012 07:15 PM
Rowsdower98
Feb 28, 2009 05:47 PM
mattfoley
Feb 18, 2008 06:35 PM
