Mystery Letters
Old Aug 18, 2005 | 12:33 AM
Carbuff's Avatar
Default Mystery Letters
Now that the top face of my block is all cleaned up and flat, I see there are letters stamped into the deck surface on the exhaust side of each cylinder bore.
On my engine they are (from #1): C D D E
What do they mean???????
Old Aug 18, 2005 | 12:48 AM
Default RE: Mystery Letters
That is info for which bearing are used on the crank.
The letters = thickness of the bearings.
Old Aug 18, 2005 | 12:52 AM
Carbuff's Avatar
ORIGINAL: tech
I suspected as much, but what a strange place to put the letters! I can see it now:
"Hey Svwen, we gotta remove anudder head to see what crank bearings goes wit each bore"
GRIN
Atwell "crazy from the fumes" Haines
NJ
Old Aug 18, 2005 | 12:57 AM
Yes but you would have to have it removed to install a new piston.
Old Aug 18, 2005 | 09:06 AM
Ignavus's Avatar
Hello Atwell; THe letters are the engine bore size codes. Each piston is fitted to each bore. C = 96.00-96.01mm D=96.01-96.02 E=96.02-96.03 G=96.04-96.05
They also ave OD sizes for the overbores. One reason why these things last so long. Sounds like you got a good one with no G or OD codes.
Diddlydoo
Jun 5, 2014 10:19 AM
jktiffin
Feb 22, 2008 09:22 AM
jktiffin
Jul 14, 2006 02:14 AM
AR
Dec 12, 2005 12:23 PM
DragonWagon
Nov 27, 2005 10:59 PM
