Need Fuel Filter Fittings
Old May 11, 2018 | 09:41 PM
Salivating11ama's Avatar
Unhappy Need Fuel Filter Fittings
So I picked up a 1991 volvo 740 from a guy who said the only thing it needed was a fuel pump. Upon replacing the pump I decided to replace the filter, where I noticed the lines needed to be replaced, and the fittings going into and out of the filter needed to be replaced due to rust but I can't seem to find anything that will work. I went to both O'reilly and autozone and they had nothing that would work at all. If you have any info for what the fitting sizes they are, and where I could find them I would appreciate the help. Thanks!
Old May 12, 2018 | 08:06 AM
act1292's Avatar
Is this what you are looking for?
https://www.ebay.com/itm/NLA-Volvo-2...-/130211483659
I expect it would be the same for a 740 but I'm not positive. Perhaps someone here can confirm.
Old May 12, 2018 | 03:45 PM
It's one of the pieces I need, but I need all the bits that go into it as well. I appreciate the help so far though!
Old May 12, 2018 | 05:19 PM
dnarby's Avatar
I've replaced the fitting-type filters with non-fitting style filters that have a long nipple such as: https://www.ipdusa.com/uploads/image...size_22412.jpg
You just cut off the fitting and just hook it up. No more rusted fitting problems ever again..!
Be sure to use fuel line clamps like this one https://www.carid.com/images/dorman/...ts/572-100.jpg (in fact, I like those a lot better than the screw type hose clamps for all hoses/lines, they just work better and are easier to use IMO).
I've been running a brick like that for a few years with no issues.
Old May 12, 2018 | 05:53 PM
Thanks man, this is probably what I'm going to do
Old May 13, 2018 | 07:16 AM
dnarby's Avatar
Happy to help (this board has helped many times).
If you have to replace rubber fuel lines, be sure to get pressure rated fuel injection line.
This is one of the easier ones to fix, I didn't even need to lift my brick.
Old May 14, 2018 | 12:24 AM
Yeah, I made sure it was all pressure rated to handle what my pump was putting out
abtdad
Mar 24, 2011 12:02 AM
jp619
Aug 1, 2010 12:16 AM
klaus
Sep 12, 2009 01:49 PM
uniquemicro
Sep 2, 2009 10:19 PM
oldvolvo
Oct 13, 2007 09:37 PM
