Need Radiator Plug for Nissens
Old Jun 26, 2018 | 10:38 PM
abro's Avatar
Default Need Radiator Plug for Nissens
I have a Nissens Radiator P/N 8603894 sold by FCPEuro. It looks like a quality radiator. However upper L/H corner is a screw thread (hole) for a thermal switch. My original rad did not have this sensor switch.
What screw pitch/thread size is the sensor? Is it American or Metric thread size????. I want to install a screw plug in place of the switch sensor.
I can always install the switch and put a vinyl plug over it. Will look kinda of hokey.
thx....great forum, great people, great help
Old Jun 26, 2018 | 11:28 PM
everything is metric on a volvo. that said, I ahve no idea what size that plug is.
and yes, people frequently use a old thermoswitch as a plug.
Old Jun 27, 2018 | 03:46 AM
dytha99's Avatar
https://www.ipdusa.com/prodtype.asp?...adiator%20plug
I used the radiator plug and the sensor seal from ipd on my Volvos.
Lubed them with some coolant and pushed them in with channel lock pliers.
Just for added security I put a stainless steel zip tie from oreillys on the plug as well.
Old Jul 5, 2018 | 06:42 PM
abro's Avatar
Default [SOLVED] - size and options below
here are the options...
(a) 22 mm x 1.50 x 3/8 in tapered metric drain plug, brass w/plumbers tape
(b) use the existing thermometric sw w/ gasket provided w/ radiator. Install with plumbers tape and use a plastic (black) chair leg protector over the sw contacts. Looks ugly but it works.
Old Oct 10, 2019 | 04:45 PM
mschultz373's Avatar
I just ran into the same problem.
It sounds like putting the electronic fan switch into the Nissens radiator and then taping the switch up to prevent use will work?
abro
Jun 27, 2018 06:30 PM
jefhon
May 7, 2018 06:17 PM
940LPT Owner
Apr 5, 2016 02:36 PM
brickrunner
Jul 20, 2013 02:19 PM
Blivit
Jun 10, 2008 09:49 PM
