no power to fuel pump
Old May 22, 2007 | 10:17 PM
oblazer's Avatar
Default no power to fuel pump
First of all whats up to everyone out there hopefully one of you can answer my ? I have a 1990 740gl , i thought my fuel pump in tank was out so i took it down and tested it with a separate batterie and it pumps just fine but for some reason the wires that power the pump on the volvo are dead no juice at all ... i followed it to circuit # 11 and that circuit is dead and didnt even pop the fuse ...everything else has power except the fuse for the fuelpump... I dont have a manual so i was wondering if anyone knows if theressome sort of fuel relay i dont know about ?
Old May 23, 2007 | 04:39 AM
JetTech's Avatar
Default RE: no power to fuel pump
There is a fuel pump relay, I don't know where it is on the 740's so hopefully someone will chime in here and help you.
Old May 24, 2007 | 12:48 AM
VolvoDriver's Avatar
I'm fairly certain the fuel pump relay/fuel injection systemrelay is going to be located on the relay panel behind the front ash tray...driver side, behind the big red relay(bulb failure sensor) and/or in front of the two smaller silver relays.
[front-back orientation is: front of Volvo is the forward whereas rear is aft.]
Old May 25, 2007 | 02:09 AM
tedv's Avatar
and it's almost always WHITE...
Old May 25, 2007 | 04:00 PM
Don't worry about the color. Call up a faithful Volvo shoppe and ask for the part number, cross reference to make sure you yourself know what you have. Don't be discouraged by nimrods.
goodness gracious what other things must one reply with?[sm=teetertooter.gif]
Old May 25, 2007 | 11:57 PM
tedv's Avatar
And it's large and square; you can't miss it... The date of production should be stamped on it somewhere-probably the original that came with the car and due for retirement. A Volvo shop may try to get you in for some "extra attention" you may need.[]
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
scrap88
Apr 7, 2010 09:23 PM
montysano
Sep 9, 2008 11:52 AM
