NO POWER HAVE TO HOLD THROTTLE DOWN LONG TIME
Old Jun 8, 2006 | 02:31 AM
ALJOSEPH's Avatar
Default NO POWER HAVE TO HOLD THROTTLE DOWN LONG TIME
I have to hold the throttle down for a while before engine come up to speed, I also noticed some smoke from the tailpipe, when idling sound like the engine is miss firing. Can someone please help me.
Old Jun 8, 2006 | 11:19 AM
cbevis's Avatar
Default RE: NO POWER HAVE TO HOLD THROTTLE DOWN LONG TIME
Is it a 240? If it is, there's a few reasons that happens. The one i'm familiar with is the fuel/air mixture. If it's running rich it'll put up a fight to stay running in the begining and progresivly get better the warmer the engine.
Old Jun 8, 2006 | 01:02 PM
ALJOSEPH's Avatar
hAY THANKS
THIS IS A 740 TURBO
Old Jun 8, 2006 | 03:41 PM
cbevis's Avatar
Well....i'm less familiar with the 740's but it still could be the problem. My sister had a 740 turbo with the same problem. I told her take it to a dealer and have them clear the computer. It worked fine after that.
Old Jun 8, 2006 | 06:42 PM
ALJOSEPH's Avatar
hAY THANKS
i DIDN'T THANK OF THE COMPUTER BEING THE PROBELM, I WILL HAVE THAT CHECKED
Old Jun 8, 2006 | 08:54 PM
Could be a bad Mass Flow sensor,O2 sensor,coolant temp sensor,Turbo
Old Jun 8, 2006 | 10:36 PM
ALJOSEPH's Avatar
CHANGED THE TURBO AND NOW IT DON'T SMOKE AS MUCH AS BEFORE STILL HAVE TO HOLD DOWN THE THROTTLE AND WAIT FOR ENGINE TO COME UP TO SPEED,
IS IT POSSIBLE FOR THE CAT AND MUFFLER TO BE GLOGGED??
Old Jun 8, 2006 | 11:12 PM
Yes possible is a check engine light on?
Old Jun 9, 2006 | 08:42 PM
ALJOSEPH's Avatar
THERE IS NO CHECK ENGINE LITE ON
Old Jun 9, 2006 | 10:00 PM
What year is it?
Old Jun 10, 2006 | 01:34 AM
ALJOSEPH's Avatar
1989 740 TURBO
Old Jun 10, 2006 | 09:45 AM
Do you know how to pull codes on the car?
If not follow link to learn how. Just because the light isn't on at the moment it might have codes.
http://www.troublecodes.net/Volvo/
Other possibilitys
Cat converter,Fuel filter.
Old Jul 1, 2006 | 02:22 PM
ALJOSEPH's Avatar
After checking all of the the common things that I was posted to check out , I was not able to fix this problem,
However just before I decideed to give up and replace the engine, I happen to remember, when I bought my boat I ran the engine onland without a load, and it ran fine, when I put the boat in the water and tried to go anywhere at some kind of speed till, the boat had no power, Hummmm!! checked everything, changed the distributor and , that fix the problem .
So I said to my self , self check the distributor on the Volvo, and I did and found the little black connector for the sensor was broken so i replaced the sensor with a new one so i tested the engine and it ran fine. so I tested the engine and a trail of smoke came out of the exhaust
But after the engine warmed up the smoke dissappered
Old Jul 1, 2006 | 04:01 PM
So is it all better now?
Old Jul 2, 2006 | 12:57 AM
ALJOSEPH's Avatar
I now have power, but it smokes like a steam engine for a while then stop smoking after it is warm, I wonder if this could be a valve problem. If so, can I use the head from the 240dl, ( THE HEAD IS IN PERFECT CONDITION ), by removing the rear seal and putting the distributor there from the 740 GLE engine.
Old Jul 2, 2006 | 01:25 AM
You would also have to use the 740 Cam. Also look at the Valve and make sure the turbo ones aren't bigger.
Have you done a compression test to make sure the compression is good?
It could also be a turbo going bad.
What color is the smoke?
Old Jul 2, 2006 | 12:40 PM
  #17
ALJOSEPH's Avatar
No I havn't done the compression check yet, I haven't pulled the heads yet . I had several people tell me that the valve maybe bad, and a valve job cost a lot of money. The smoke smell like gas, and about the same color as the smoke in your picture.
Old Jul 2, 2006 | 02:15 PM
  #18
Black= Running rich
White= means bruning coolant
Blue means burning oil
I would do a compression test.
Then if something seams low Squirt some oil in the cylinder and retest. That will rule out rings.
Old Jul 3, 2006 | 12:05 AM
  #19
ALJOSEPH's Avatar
i WILL DO COMPRESSION TEST FIRST THING IN THE MORNING
Old Jul 3, 2006 | 01:19 AM
  #20
Post results and I will look them over tomorrow night.
