NO POWER HAVE TO HOLD THROTTLE DOWN LONG TIME
Old Jul 3, 2006 | 11:27 PM
  #21
ALJOSEPH's Avatar
Default RE: NO POWER HAVE TO HOLD THROTTLE DOWN LONG TIME
Well I checked the compression . 1) 150psi 2) 120 psi 3) 120 psi 4) 150 psi , I took the car for a drive today It seems to run great , but after driving for say 10 min. when I stop at a stop sign it seems to Idle rough, and act like its runng hot but the guage said different in the normal range, have a little pinging or knocking sound at take from stop sign and the smoke is not as bad as when it is cold. Got on the freeway and the car runs danm good
Old Jul 4, 2006 | 12:21 AM
  #22
See if it keeps getting better. It might still be burning the oil out of the exhaust system.
Also look and see how dirty the throttle body is.
Has anyone messed with the throttle body before?
Old Jul 4, 2006 | 01:46 AM
  #23
ALJOSEPH's Avatar
The throttle body is fairly clean, as far as someone mess with it I'm not sure, the car had these problem when I purchased it for a whooping $100.00 bill, you think I should check the valve clearance if so what should it be?
Old Jul 4, 2006 | 02:02 AM
  #24
First check the throttle switch for the Idling problem. Turn the car off. Then open the hood and get close to the throttle body. Listen closely with you ear and open the throttle slowly. Listen for a click just above closed position. It should click just above closed/idle. If it doesn't then the idle motor might not be working at idle.
Old Jul 14, 2006 | 01:51 AM
  #25
ALJOSEPH's Avatar
Hey forgot to tighen the distributor car now idles ok still hqave smoke, However someone told me that it could be the turbo, and before I purchased this car the other owner though itwas the turbo and replaced it ( remember the the probelm started with lack of power with the smoke) i GOING TO PUT THE OLD TURBO BACK ON THE CAR AND SEE WHAT HAPPEN.
Old Sep 3, 2006 | 02:40 PM
  #26
ALJOSEPH's Avatar
Replaced the turbo I have less smoke, car seems to run better, however after about ten or fifteen miles it seems to start knocking. should I be looking for a new engine or have this one rebuilded?
Old Sep 5, 2006 | 07:39 PM
  #27
Is it running hot?
Old Sep 5, 2006 | 11:38 PM
  #28
jfunez's Avatar
hey joseph...It might be a good idea to check the timing on the belt, cam could be a tooth off.
I,ve seen it before on my 940... all the simptoms that you have described were apparent on mine.
Its easy to do and it could possibly save a lot of time and money...
[IMG]local://upfiles/4632/6ACB90FD7B0343D4BD085F714636F897.jpg[/IMG]
Old Sep 6, 2006 | 03:24 AM
  #29
ALJOSEPH's Avatar
not hot on the gauge, the needle seem to stay in the middle. how ever it runs like its getting hot
Old Sep 6, 2006 | 03:29 AM
  #30
ALJOSEPH's Avatar
Thanks jfunez
I'll check the timing again .do the timing mark for the oil pump have to be right on the mark ? or do it matter when the distirbutor is on the rear of the head.
Old Sep 6, 2006 | 08:34 PM
  #31
It is better to have it lined up. The shaft from the pulley in is also a counter balance shaft.
little-red-wagon
Jul 19, 2015 02:31 PM
Capthook
Sep 3, 2013 08:47 AM
gratakon
Mar 4, 2009 05:22 PM
megatrack
Oct 4, 2007 02:53 AM
Uhills
Apr 5, 2005 08:22 PM
