No signal lights or tail lights
Old Nov 3, 2008 | 06:09 PM
concongb's Avatar
Default No signal lights or tail lights
Help, I need to find the fuse listing for a 88 244 DL, my teenage son has broken and thrown away the kick plate. The car has brake lights but now tail lights and the battery light is also on. Does anybody have the listing from the pannel.
Old Nov 4, 2008 | 04:29 PM
billofdurham's Avatar
Default RE: No signal lights or tail lights
Some of the equipment listed below is optional
1 Cigarette lighter, El. operated side mirrors, Radio, Tailgate wiper/washer, Cruise control (governor) 8A
2 Windshield wiper/washer, Horn 16A
3 Heater blower 25A
4 Fuel feed pump (tank) 8A
5 Spare
6 Main fuel pump 16A
7 Brake lights, Cruise control (switch) 8A
8 Interior light. Glove box light, Trunk light, Engine compartment light, Central locking, El. radio antenna, clock 8A
9 Hazard warning flashers, shift indicator light 8A
10 Power windows 16A
11 4th gear (automatic transmission), heated rear window 16A
12 Back-up lights, Window lifts (relay), Air conditioning (with blower control), Rear window demist (switch) 8A
13 Turn signals, seat belt reminder lights, heated front seats, fuel injection system 8A
14 Rear fog lights 8A
15 Parking lights (left side), License plate light 8A
16 Parking lights (right side), Light on instruments and controls 8A
Blade type fuse, serving LH-Jetronic fuel injection system. Located on the left wheel housing by the ignition coil 25A
Refer to the fuse location chart at fuse box for fuses specific to your car.
You can also find an on-line owner's manual at: http://new.volvocars.com/ownersdocs/...0/88240_00.htm.
The battery light will not be a fuse problem. Could be a drive belt or alternator.
Old Nov 4, 2008 | 05:38 PM
concongb's Avatar
Thank you so much, I am trying to teach my son to work on his own car and take care of it, pray for me,[sm=alcoholic.gif]. I have a long journey. Thank you again.
Old Nov 5, 2008 | 01:40 PM
You are welcome.
I tried to teach my son-in-law to work on his car but after he let the jack down then tried to remove the axle stand, not once, not twice but three times I gave in and did the work myself.
Good luck.
88740gle
Nov 13, 2015 08:13 AM
commoncold
Jun 25, 2014 10:38 PM
buellfire
Jun 20, 2009 12:37 AM
Mosesita
Jan 21, 2009 06:06 PM
marvb1
Mar 24, 2007 05:35 PM
