no spark on 86 240dl
Old Jul 19, 2006 | 01:29 PM
tx_faktors's Avatar
Default no spark on 86 240dl
I have a 1986 240 dl with an engine that was just replaced last year. Biggest mistake of my life. It has less than 500 miles since replacement. My current problem is a lack of spark from the coil. I just replaced the coil with a Bosch OEM part, everything matches to the old one. I have checked that there is power to the coil. What can I possibly do next?
Old Jul 19, 2006 | 09:47 PM
Default RE: no spark on 86 240dl
Could be the Hall affect switch in the distributor.
Old Jul 20, 2006 | 12:31 AM
tx_faktors's Avatar
What is that and how do I fix it? I have checked for spark at the coil and there was nothing. Would the distributor affect that? A co-worker mentioned something about a crankshaft position sensor also. I am at wit's end here. Any help would be great.
Old Jul 20, 2006 | 12:44 AM
Possible if you have one.
Do you have an Electrical connection on the Dist?
If so it could be it.
Check the speed sensor as well. It goes into the Back of the engine where the Trans meets the engine.
If the outer black sheilding is Cracked or coming off replace the sensor wether it fixes it or not.
Because if that is not the problem it will most like be the Next problem.
volvoQ's
Apr 23, 2011 10:00 PM
kags1969
Jun 14, 2010 10:47 PM
Cherry_Pirate
May 15, 2010 01:54 AM
futbolfan15
Apr 2, 2010 09:56 PM
bbruneau
Sep 19, 2008 06:51 PM
