occasional alternator charging problem
Old Nov 22, 2025 | 11:29 PM
240WStick's Avatar
Default occasional alternator charging problem
hi all, i have a 1992 volvo 240 wagon m47. some history on this issue, it all started over a year ago when, when i replaced my engine mounts, i removed the alternator for easier access and when i put everything back together i forgot to tighten the alternator positive wire nut and the positive wire jumped around and melted the stud, i had the alternator tested and is good, i have tried a different alternator and same issue. my current issue is that once in a while when i start the car the dash lights stay on while the car is running, and the alternator is not charging and battery volts is 12.2v with engine running, but once i rev the engine the alternator starts charging normally, with battery volts at around 13.4v or if i release the parking brake before revving the engine the dash lights go off and alternator is charging fine. i have checked the wire under the engine and is good. also whenever i turn on the headlights the engine bogs down a little or when i use anything electrical.
any thoughts or suggestions?
Old Nov 25, 2025 | 09:15 AM
start by checking battery connections at the terminals then check the ground strap to chassis connection. Next check the positive cable for any swelling / bubbles on the insulation. Next clean the connectors to the alternator wires. If the engine bogs down when you put a load on the electrical system, I'd be thinking it's time for a new alternator since it sounds like it can't produce enough amps. Also, 13.4 V with the engine running is barely enough to charge the battery - I'd expect 14V+ with no load and maybe high 13s with a bunch of accessories. So try this - engine off, measure battery voltage. Should be 12.6- 12.8 for a 80%+ charged battery. If its 12.2 with the car off, your battery is weak and should be replaced. Now start the car and check voltage with no accessories/lights etc. Measure the voltage. Should be 14+ V. Next turn on the high beams, rear defogger, AC blower. Measure voltage - should be 13.5+. If this is below 13 then your alternator isn't producing enough amps.
Old Nov 25, 2025 | 04:57 PM
Golden redblock's Avatar
Default Alternator
L&D Volvo Redblock parts
Atlanta Craigslist
Shipping Nationwide!!!!
Completely independent!!!!
Old Dec 13, 2025 | 06:05 PM
240WStick's Avatar
I found out that the voltage regulator brushes are very worn down and uneven.
would this cause my issue?
Old Dec 14, 2025 | 08:54 AM
act1292's Avatar
Certainly worn brushes will cause charging problems. It doesn't explain why a replacement alternator didn't solve your problem though nor does it explain the dash light problems, etc. Since they are worn go ahead and replace them.
Old Dec 27, 2025 | 04:42 PM
240WStick's Avatar
I rebuilt the alternator and installed a good used regulator with good brushes and now it charges to 14.2V-14.3V.
Old Feb 18, 2026 | 12:04 PM
renardanderson2's Avatar
Old Apr 9, 2026 | 05:42 PM
240WStick's Avatar
I rechecked the voltage again and the alternator is charging to 14.4v and with headlights on the battery is at 14.1v. My car no longer has A/C.
Old Apr 10, 2026 | 05:25 PM
Johnsf's Avatar
Enough current to melt the alternator stud would have to come from the battery. Sounds like a possible short in the alternator. It may be an intermittent fault to not show up when the alternator was tested.
silvermine
Nov 10, 2021 02:30 PM
amazonPhil
Oct 13, 2017 07:52 PM
Crow78945
Mar 11, 2015 01:15 AM
mrwrick
Jan 29, 2009 07:16 PM
gman2
Mar 28, 2007 01:17 PM
