charging issue
Old Oct 30, 2021 | 03:15 PM
silvermine's Avatar
Default charging issue
only 11.8 volts at idle.. checked d+ wire which is sketchy.. seems to be getting voltage KOEO .. when grounded to alt. any ideas?
Old Nov 1, 2021 | 10:35 AM
silvermine's Avatar
ok did a few more tests since it finally stopped raining. fuse 13 is ok. disconnected D+ wire at alternator and grounded to a good engine ground. with KOEO all lights on dash
light up. checked voltage on D+ wire = 12v. reconnected D+ wire to alternator KOEO no BATT light on dash. so, based on that suppose D+ wire is ok? I grounded alternator to engine
with a jumper and got same result KOEO no light on dash...
what would be the next step ? remove alternator and get it tested ?
Old Nov 1, 2021 | 02:52 PM
Originally Posted by silvermine
a good engine ground. with KOEO all lights on dash light up.
Replace the bad alternator. You tested the D+ circuit, all lights are working when grounded. You tested the ground on the alternator (the alternator is mounted in rubber and has a ground strap) You tested the charging rate - it's not charging if you are getting 11.8 volts. (and the belts OR the crank shaft vibration damper are not slipping badly)
Old Nov 2, 2021 | 10:53 AM
silvermine's Avatar
thanks reply. i pulled the alternator and had it tested at advance which it failed. removed voltage regulator and one of the brushes just fell out of it... ie wire was broken.
going to replace the regulator before the entire alternator and see what happens....
Old Nov 6, 2021 | 02:05 PM
silvermine's Avatar
ughh, new voltage regulator didn't work.. same symptoms no lights on dash. now it gets worse engine will crank but not start...
..on to more troubleshooting... can't even hear main fuel pump prime with key in position 2. pulled a spark plug looked normal.
Old Nov 8, 2021 | 10:05 AM
silvermine's Avatar
ok so the engine started today (good news) but still only getting 11.8 v at idle so gonna pull the alternator re-check the installation of the new voltage regulator
and take it back to get bench tested again...
Old Nov 8, 2021 | 04:05 PM
silvermine's Avatar
it lives! took the alternator to an old guy nearby who soldered a busted wire inside the case that connects the D+ terminal to the voltage regulator.. so now charging.
no AAA this time... lol..
Old Nov 8, 2021 | 04:16 PM
amazing you found a shop who'd actually work on the unit!! Great find. My personal pet peeve is cars where the voltage regulator is not separately replaceable from the Alternator. Just had to drop $500 for VW alternator due to an issue with the voltage regulator... Somewhere a shop is going to rebuild my unit and resell as "remanufactured".
Old Nov 8, 2021 | 04:30 PM
lev's Avatar
lev
There is really little to an alternator that can go wrong so rebuilding them is easy. The brushes (regulator) wear out and and are the problem 99% of the time. The rest are a couple of bearings that wear out after 500k miles and some basic circuitry...
Old Nov 8, 2021 | 05:33 PM
yep, my issue was a relay in the regulator that disliked really cold weather so on the coldest days, it would stop charging from time to time. Turn the car off/on and it would start charging again.
Old Nov 8, 2021 | 06:05 PM
silvermine's Avatar
yeah i was surprised. went to an old guy (like me lol) ... my son had a MKIII golf and we went through 3 alternators from autozone before before we got one that would work... in the winter.. outside.. lol..great fun
Old Nov 9, 2021 | 04:33 PM
silvermine's Avatar
hey mt do you remember a guy down on route 7 wilton... used to work on Peugeots, and MB, and Jags...
Old Nov 10, 2021 | 01:37 PM
I know the shop - but never used it. When I had my 84 Audi Quattro, I used a shop across from the Branchville train station (old stone building with euro cars out front :- )
Old Nov 10, 2021 | 02:30 PM
silvermine's Avatar
that's the building where my friend had his shop! right beyond the stoplight after the train station going north. #63 US7 ..now seems to be called keane autoworks...
i would travel up there after he left a place in new canaan. ...small world..! (sorry shud have said in ridgefield not wilton....:-)
WagonDaddy
Dec 4, 2020 08:23 PM
that4wdwagon
Nov 2, 2014 05:15 PM
Juliet Foxtrot
Jun 9, 2011 01:55 PM
neveradullmoment
Sep 6, 2009 08:33 AM
USSEnterprise
Oct 4, 2006 09:34 PM
