Oil leak
Old Aug 25, 2006 | 07:40 AM
Volvo240guy's Avatar
Default Oil leak
Hello I want to thank you for all your help in the past. Now I need help agian.. I have a small oil leak I saw oil on the bottom of the drain plug and then I did not. I had changed the oil and put a new copper washer on the plug and now it looks like their is oil on the bottom of the plug. I have noticed the it looks like it is wet under the floor boards under the car but I run the AC all the time as it has been very hot here so Im thinking that is from the ac draining. But it does not look like their is any oil usage when I check the oil and the car is a manual and is shifting fine and the power steering is full and brake is full so help if you have any ans to this with all your wisdom......
Old Aug 25, 2006 | 08:40 PM
Default RE: Oil leak
Might be Excess leftover from changing the Filter. It will make is way there.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
