Out in unfamiliar territory..
Old 07-02-2014, 03:12 PM
Tuunikala's Avatar
So..
Listed the car for sale, drove over 1000k in 3 days (with no faults and full load), registered the car to my name (was waiting for my payday), insured it (3 months) and finally, ordered the gas "carb" repair kit (mine isn't working due to broken membranes and gaskets).
And, soon I'll get some chrome trim, tinting windows, updating audio, repairing headliner and hopefully repairing the alloys or changing them, we'll see.
But, the car is working fine, no faults, no nothing. And since there hasn't been any interest about the car, I'll probably start doing maybe even more small things to it..
Thinking about cutting the cat off and upgrading the exhaust, but will it make any difference, besides a throatier exhaust note?
  #22
Old 07-02-2014, 04:06 PM
Carburetors on a volvo 240/740/940 with a catalytic converter? what year/model car and engine ARE we talking about?!?
re: hacking the exhaust, on any volvo brick I've had, I seriously doubt you'd get anything but more noise and pollution out of modifying the exhaust unless you've also done EXTENSIVE engine modifications to greatly increase the total air+fuel flow
  #23
Old 07-02-2014, 11:39 PM
Tuunikala's Avatar
Alrignt.
And by the phrase "Gas carb", I meant the carburetor for the lpg system, which is on the left side of the engine:
And basically, not worth it to modify the exhaust system then.
  #24
Old 07-03-2014, 12:29 AM
um, if you're running some kinda aftermarket LPG system on your volvo you're pretty much on your own.
it does look like your air input hose is kinked, that could restrict the amount of air at full throttle high RPM and negatively impact performance.
how is the LPG metered? LPG gas mixers aren't actually carburetors, they are air-gas mixers, sort of another form of fuel injection, and somehow the gas has to be metered to match the airflow demand of the engine... does it still use the MAF/AMM ? (thats what provides the control signal for how much gasoline would be injected on a conventional car).
  #25
Old 07-03-2014, 12:00 PM
Tuunikala's Avatar
The air hose is kinked, due to the gas input point. It doesn't use the MAF to control LPG input, but it uses vacuum generated by the intake system to measure the amount of gas needed. It's kind of old-fashioned, but hopefully, after the membranes are changed, it will work.
But, I have no idea, how to remove the kink from the air hose. I don't want to remove the LPG system, maybe cutting the hose a bit will help? But, then again, will I be able to reattach it then..
The system is specially made for Volvo by Vialle, and already ordered some parts off ebay. Hopefully they are the ones I need.
  #26
Old 07-03-2014, 01:12 PM
so the stock fuel injection system is completely disabled? or is this car setup to be dual fuel so you can use either gasoline/petrol or LPG ? if the EFI is entirely disabled, maybe removing the MAF entirely would give you sufficient room to unkink the hose.
or, replace that elbow piece between the MAF and corrogated hose with something shorter. and or replace the elbow AND corrugated hose with a longer piece of corrogated hose, as long as you can achieve a reasonable air-seal against the air filter box.
  #27
Old 07-04-2014, 01:34 AM
Tuunikala's Avatar
It's dual fuel, it uses gasoline to start the engine, then I can switch over to LPG.
So, I need the MAF etc to drive on gasoline.
But, I'll see what I can do about the hose. I'm thinking about using aluminum and silicone or just silicone hoses to deal with the situation.
  #28
Old 07-04-2014, 02:17 AM
anything that fits and is air tight. you don't want any air leaks between the MAF and the throttle, but its not under any vacuum (unless your air filter is badly clogged).
  #29
Old 07-08-2014, 12:01 AM
Tuunikala's Avatar
No, the filter is recently changed, so no problems there.
But at the moment, still waiting for parts, hopefully they'll be here soon.
  #30
Old 07-20-2014, 02:41 AM
Tuunikala's Avatar
So, long time no see.
Anyway, got the parts, but it still doesn't work. And by it, I mean the LPG-system.
Hopefully it's something easy and simple..
derekmw
12-21-2012 11:43 AM
ewgoforth
07-29-2012 09:45 AM
benschumacher
08-13-2010 02:43 PM
Keith Tobberman
08-09-2008 11:35 AM
Quick Reply: Out in unfamiliar territory..
