Overdrive issue
Old Jul 23, 2019 | 03:58 PM
  #21
revolvus's Avatar
I had the same issue on our 91 240. It was an insulation failure inside the shifter housing of the wire that runs down to the solenoid. The short killed the relay. Ran a new wire and replaced the relay and 4th gear worked.
Old Aug 19, 2019 | 09:52 PM
  #22
Malbone's Avatar
Just a thought that if the button was missing when you bought it, perhaps a mechanic disconnected it because it was faulty and the mechanic thought you really don't need it in most situations.
Old Aug 20, 2019 | 08:09 AM
  #23
waginc2u's Avatar
Simple solution: Get the soleniod bypass kit from IPD and in 15 minutes you have the transmission shifting through all four gears.
https://www.ipdusa.com/products/4793...110397-1239928
Don't forget to remove the light socket from the dash.
Downshift manually D to 2.
Old Aug 20, 2019 | 07:35 PM
  #24
jagtoes's Avatar
I just ground a slot in the old solenoid and it works the same way. A quick fix.
ChaseVolvo
Dec 26, 2014 01:21 PM
ctmca9
Jun 7, 2014 09:44 PM
newowner
Aug 15, 2013 12:18 PM
rmccotten
Feb 17, 2013 09:32 PM
nmwagon
Aug 29, 2007 12:51 PM
