Overdrive Problems on my 244
Old May 30, 2007 | 03:15 PM
funnyguy44444's Avatar
Default Overdrive Problems on my 244
Another small problem with my reliable '82 244 GL. Last month my overdrive started acting up. It seems like it has a mind of its own. It switches off and then back on again randomly while im driving. when it switches off i can't turn it back on by hitting the OD button because no matter how many times i hit it it does nothing. But the OD button works fine when the OD is operating normally. I suspect that there is just a relay or something else electrical that i need to replace. Does anyone know hwat it is and where it is? Thanks,
-Nick-
Old May 30, 2007 | 04:35 PM
billofdurham's Avatar
Default RE: Overdrive Problems on my 244
There is an overdrive relay located under the centre of the instrument panel.
Other possible causes:
1. Faulty overdrive solenoid.
2. Fault in the wiring between the switch and the solenoid.
3. Low oil level in the overdrive unit.
4. Blocked oil filter in the overdrive unit.
Old May 31, 2007 | 10:26 AM
TedH's Avatar
go on IPDUSA.COM and buy the overdrive overridekit. it would fix your problem though you wont be able to manually take it out of overdrive.
Old May 31, 2007 | 11:06 AM
I'm gona start by checking the relay because its cheap and easy if that doesn't fix it then i'll check the solenoid. Thanks for the tips guys.
Old May 31, 2007 | 09:22 PM
The relay was the problem. It was a quick fix i didn't even need a new relay i just took a soldering iron and some solder to the connections on the back of the old one and now it works like a charm!
Old Jul 5, 2007 | 09:56 PM
bil6ft6's Avatar
got mine fixed, but can't find any info on where or what triggers overdrive. linkage, vacuum, throtle position?
lilsilver85
Aug 29, 2014 04:07 AM
mkasperbauer
Apr 22, 2012 09:06 PM
az242
Oct 17, 2008 04:03 PM
mattfoley
Feb 18, 2008 06:35 PM
kleuch48
Mar 14, 2005 10:29 AM
