Overdrive Relay - Replace?
Old May 25, 2008 | 03:54 PM
alexi3rdgen's Avatar
Default Overdrive Relay - Replace?
I finally found the overdrive relay!
I took the glovebox out, and it wasn't there...just about the time that the Volvo Forums went down, and I couldn't figure out how to get the lower part of the dash/console out to find it. Anyway, the Haynes manual has much better instruction than Bentley on radio removal, and I finally got it out. Well, the relay had fallen underneath the front vents, and it looked like it might not have been all the way plugged in, so I can check it when I get the car running again. But here's the weird part...I can click the overdrive button and the O/D Off light comes on, but sometimes it won't click back. I tried a bit of "percussive maintenance" and when I smacked the relay, the O/D Off light switched off. Is this a bad relay, or a failing relay, and a bad solenoid? I plan to convert it to a manual, but if I can have fourth gear in the meantime, that'd be dandy.
Wes
Old Jun 18, 2008 | 05:37 PM
ol yeller's Avatar
Default RE: Overdrive Relay - Replace?
dude just get a bypass plate or cut a groove between the holes on the switch. use a dremel. plate costs 40 bucks from ipd or free if you have the tools.
lilsilver85
Aug 29, 2014 04:07 AM
Fisherman
Aug 3, 2005 10:02 PM
Fisherman
Jul 31, 2005 11:44 PM
diddydohjo
Mar 14, 2005 10:12 AM
bli745
Mar 10, 2005 08:34 PM
