overheated engine and clunking noise
Old Feb 4, 2009 | 11:11 PM
VbuddhaV's Avatar
Default overheated engine and clunking noise
My son informed me earlier that his '81 240 temp gauge rose to the top earlier on his way home from school. He said his heater hadn't worked for the last couple of days too. We checked the coolant level and sure enough, it was low, so we filled it up. No more overheating. But... the engine makes a kind of clunky rattling sound that I had never heard before. It sounds like it's coming from the front of the engine in the area of the timing belt or water pump. Timing belt was recently replaced. I don't think he drove it long enough to do any serious damage so I'm wondering what it could be. Any suggestions guys? All input is appreciated.
Old Feb 5, 2009 | 02:22 PM
soundmiami's Avatar
When my kids tell me the car is "kinda hot" and "smoking a little" she means they're on the side of the road and the only reason they've stopped is they can't see out the windshield because the wipers don't work well on a steamy mixture of water and ethylene glycol.
You could take off the fan belt to disable the water pump and see if the noise goes away. .
Old Feb 5, 2009 | 03:41 PM
blue goose's Avatar
Suspect bad water pump. A good time to change it is while you're changing the timing belt because you're already in there and it saves on labor time.
meatpotatoes
Jun 13, 2012 07:20 AM
meatpotatoes
Jun 9, 2012 11:34 AM
crzicrzi
Feb 29, 2012 10:41 AM
radio16
May 15, 2010 11:22 PM
