Pictures of ground locations
Old Apr 3, 2019 | 08:00 PM
Zombi's Avatar
Default Pictures of ground locations
The 87 wagon I have has lots of electrical gremlins. Largely due to corroded grounds. The hardest part was finding the ground locations. The members of this have been helpful, but for a novice like myself pictures are nice.
Did I mention that this snake feasted for years in this car while parked and got to be 3 feet long. Rodent problem.
Trans selector light. There is a ground not pictured on the other side.
Ground on trans tunnel driver side. You may be able to access this without removing the seat and carpet.
Rust never sleeps
Ground above air control
The black ganged ground on the steering column got the black ground in the large circular female connector working, and then the dash instrument illumination lights came together.
Old Apr 4, 2019 | 03:44 PM
note they tend to use different grounding points for 'signal' grounds vs 'power' grounds. this reduces noise in the more sensitive signal circuits. on the engine itself, there's two grounds, one for power hungry stuff like the injectors, other one for sensitive stuff like the sensors. diutto, the left and right dashboard grounds are segregated the same way, I *think* its power on the left, signal on the right, but I might ahve that backwards
Casey Wigginton
May 28, 2018 10:27 PM
PinnacleWax
Nov 11, 2014 04:38 PM
S70driver
Sep 16, 2012 11:03 AM
turbosundance
Jul 26, 2010 12:53 PM
