Please help with radio problem
Old Jan 21, 2007 | 05:59 PM
heifetz17's Avatar
Default Please help with radio problem
The radio in my '89 740GL isn't working right. It's the factory radio, and there's just static all the time. I thought the antenna was the cause since it was missing, but upon installing a new one, the problem hasn't changed. Every rare once in a while it will work, but as soon as I hit a bump, it goes back to static. The funny thing is, if I hit the center armrest or slam it down, it will bring the reception back in, but only for a short while, then it goes back to static. Tapes work great, just the radio has static. Any ideas of what's wrong?
Old Jan 21, 2007 | 06:24 PM
brohism's Avatar
Default RE: Please help with radio problem
Have you checked the wire that runs from the antenna to the back of the radio? It could be that it's loose, so when you go over bumps it's shifted and will therefore change the reception. I had a similar problem with my radio.
Old Jan 21, 2007 | 06:44 PM
heifetz17's Avatar
As a matter of fact, I did take the radio out and check all connections behind it, and all were ok.
Old Jan 24, 2007 | 08:45 PM
Sounds like the main wire from the Antenna to the Radio is bad.
Old Jan 26, 2007 | 10:32 AM
heifetz17's Avatar
I suppose that's a nightmare to fix. And where could I get a new one?
Old Jan 26, 2007 | 08:52 PM
I think radio shack will be the best place to get one.
Old Feb 10, 2007 | 12:37 PM
CHRIS100671's Avatar
I had the same problem with a ford truck. The wire kept dropping off the bottom of the antenna. The aftermarket replacement was one piece and ended the problem. A tree in a storm took the one from my 740. It wasnot that bad to replace. I just took my time. I have a wagon so it maybe different.
Old Feb 13, 2007 | 03:01 PM
TheVolvoMan's Avatar
On my 960, it is only the FM stattion which has the same problem as you had. Since then, I became a very relious man. Simply cross my finger and pray for Allah, God, Lord to bring it back to life. Most often my prayersare answered after few minuts of hesitations.
herbeapuce
Jan 18, 2024 06:43 AM
mitch603
Oct 15, 2008 10:30 PM
mitch603
Oct 13, 2008 04:39 PM
walpoo
Jul 27, 2008 11:42 AM
