Possible Bad Engine/Trans Mounts?
Old May 20, 2005 | 01:00 PM
proudmonkey's Avatar
Default Possible Bad Engine/Trans Mounts?
While I'm on a roll with problems I thought I would ask some more questions. I've noticed that my automatic trans shifter moves when I come to an abrupt stop. Does this mean my mounts are failing?
Old May 20, 2005 | 01:57 PM
Default RE: Possible Bad Engine/Trans Mounts?
They could be very weak.
They are pretty easy to check.Look under the car and where the oil pan goes over the cross member.If they are weak/bad the oil pan will rub on the crossmember.
You should also be able to look at the trans mount and tell if it is bad or not.
86volvoguy
Apr 20, 2017 10:50 PM
mystveous
Suspension
Apr 17, 2014 04:19 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
daver80
Jun 4, 2010 10:19 AM
tr_car_nut
May 9, 2008 08:30 AM
