92 740 sway bar link question
Old Jan 31, 2005 | 12:48 PM
RocknTommy's Avatar
Default 92 740 sway bar link question
740 Wagon, Passenger side sway bar link was broken in half.
replaced both sides and put in polyurethane bushings. A month later the passenger side was broken in half again! Am I putting these on too tight or something?
Could not find tightening specs. Thanks!
Old Jan 31, 2005 | 12:57 PM
Default RE: 92 740 sway bar link question
I would try to check good and make sure something isn't bent.You tighten down on them till the start smushing.If it keeps breaking in half either something is bent or someone keeps hitting a huge pot hole.Make sure the sway bar or the lower control arm isn't bent.You might have to have an alignment done to tell you if something is bent.
Old Jan 31, 2005 | 01:35 PM
RocknTommy's Avatar
I checked and things look OK ...car tracks straight. No major pot holes etc. The only thing I can think of is the sway bar is bent but it looks fine to me. This time I made them less tight and will see what happens. Thanks for the input!
Old Jan 31, 2005 | 02:41 PM
No problem anytime.
Old May 19, 2005 | 06:28 PM
RocknTommy's Avatar
Default RE: 92 740 sway bar link Update
Well the drivers side went again and I went over everything to see if all is right.
And it was so here is the deal. Looking at the break in the swaybarlink, its a clean break but in the middle is a line of rust. (there are new from Volvo) I think I bought a bad batch of poor quality links. 4 of them now!
The front struts are not new but they are not beat either.
But when pushing down on the bumper, you can feel the struts get a little hard towards the end of travel. So I am pretty sure the are bottoming out and that put the xtra tension on the swaybar links. This was driving me crazy but I think I have it all figured out now.
Old May 19, 2005 | 07:54 PM
That is very possible.
Also when you install the new link drop it down and look at both sides good.
Make sure the sway bar itself isn't bent.
Make sure with it on the ground both sides are at similiar angles.
Old May 20, 2005 | 02:28 PM
RocknTommy's Avatar
The swaybar is fine. Just one of those quirky things and just thought I would post my findings so if someone has the same issue of links breaking over and over again it might steer them in the right direction fir the cause of the issue.
Old May 20, 2005 | 04:40 PM
Ok it just sounds like something is bent somewhere.
urdrwho
Nov 23, 2014 09:49 PM
91shelby
Apr 6, 2012 04:19 PM
lotusing
Nov 21, 2011 04:57 PM
RedS70guy
Dec 9, 2010 03:19 PM
vetalbig
Mar 26, 2008 06:33 PM
