Possible death of a B21
Old Apr 22, 2021 | 05:38 PM
another-project-car-please's Avatar
Unhappy Possible death of a B21
Hello all,
my girlfriend bought a 78' 244DL with a blown headgasket, when i pulled it apart i found the head was cracked. tracked down a new head, swapped the cam and any other little parts and bolted it back together, flushed the oil twice and called it good. simple enough right? that was 3 days ago and it has done about 200 miles with the new cylinder head without issue except for a slight miss at idle.
however (dun dun dun)
i went to drain the oil and replace it with something a little thicker today, and what came out was very shiny... which was a very unpleasant surprise.
the only idea i have, is that when i swapped the cam i did not swap the buckets on the lifters, i used the ones that came with the new head because the old ones looked like hammered ****. now i have a hunch im watching the camshaft drain out of the bottom of the motor
if anyone has any ideas or something i missed (or maybe leads on another B21 for sale) please let me know. looking forward to driving it home wigging out about every possible knock
Old Apr 22, 2021 | 07:19 PM
Just curious if you adjusted the valves? (replaced shims in the top of the buckets to set the correct clearance?)
And to say something about cams - never saw a worn cam in a b21/23/230, some ugly valve shims, but no cams. (many in the v-6 of that vintage however)
Old Apr 28, 2021 | 08:28 PM
yes the valves have been adjusted, and ive now put more than 300 miles on it and nothing is knocking, so i think i will just play the waiting game. however thank you for the reply
lifeofgold
Oct 6, 2016 01:00 PM
lifeofgold
Oct 2, 2016 07:51 PM
pdieni
Nov 30, 2010 03:14 PM
pdieni
Sep 12, 2010 06:39 PM
joker834
May 15, 2010 07:47 PM
