POWER STEERING CUTS OUT AND THEN NOISE
Old Oct 3, 2006 | 06:17 PM
Volvo240guy's Avatar
Default POWER STEERING CUTS OUT AND THEN NOISE
Some times it is as if I have no power steering and then it seems to work good. Then when I turn sharp it cuts in and out then makes a noise. But it is like I have no power steering some times like it just does not work... but then it it is just fine like nothing ever happen.... PLEASE HELP IF YOU CAN
Old Oct 3, 2006 | 09:49 PM
Default RE: POWER STEERING CUTS OUT AND THEN NOISE
Is the belt adjusted properly?
It runs off the A/C compressor so check that belt as well.
Old Oct 3, 2006 | 10:09 PM
I found that the bolt that adjust the belt on the pump the nut had come off but the threds are striped where can I find a bolt that is the one where the adjust runs thu the head of the bolt Let me know if you could please
Old Oct 3, 2006 | 10:11 PM
Dealer or Junk Yard.
garypettengill
Apr 1, 2014 06:39 PM
das8track
Feb 5, 2013 04:51 PM
chrisgy
Feb 14, 2011 12:03 PM
maitresaman
May 1, 2007 02:02 PM
JeremyR
Aug 3, 2006 05:36 PM
