radiators
Old Sep 30, 2006 | 03:51 AM
WagHag's Avatar
Default radiators
Are there radiators made specifically for turbos? If you had a regular radiator and did a side by side comparison to one that's being sold as a turbo radiator, would they be similar? It's a difference of about $150, so I just wanted to make sure before I buy.
Thanks,
Old Oct 1, 2006 | 09:06 PM
Default RE: radiators
They might look the same but might not depends on the Brand.
Old Oct 2, 2006 | 01:52 PM
WagHag's Avatar
I guess what I really want to know is if there's a difference in volume. All the connections appear to be the same. Hypothetically, if the hoses going both in and out are the same size, then the capacity of the radiator shouldn't matter, right? I'm just suspicious that the guy is trying to jack me 'cause I mentioned the word "turbo".
Old Oct 3, 2006 | 09:02 PM
Well there is a 2 row and a 3 row avalible for your car.
It might run a Tad warmer with the 2 row but not really enough to matter.
Old Oct 3, 2006 | 11:14 PM
ldf602's Avatar
I just had my radiator replaced in my 740 non turbo. Quotes for 2 row were $250, and for 3 row, $350. My 89wagon had a 2 row and the guy did it for $200 even. Hope this helps. He didn't replace the thermostat though so on Tech's advice i did that. It was $12 bucks and the old one was in fact broken.
Old Oct 4, 2006 | 12:38 AM
WagHag's Avatar
Well, I doubt boiling water would spew from my motor if I lacka row. I've got a new thermostat and water pump I put in about 3,000 miles ago. I live in a mild climate, and most of my usage is highway or just short trips around a tiny little town. I'll go with the cheaper two row and save the difference for an upcoming turbo rebuild. If something bizarre happens or things start going to crap, I'll let y'all know.
Thanks
Old Oct 4, 2006 | 12:43 AM
I think you will be fine with the 2 row.
brickrunner
Apr 10, 2012 03:36 PM
dieselcruiserhead
Feb 5, 2010 06:28 PM
adamdallas
Jun 26, 2009 03:41 PM
Michaelrose
Feb 25, 2009 07:37 PM
