Is Pre-heat hose really necessary to pass Emission Test
Old Jul 15, 2011 | 03:03 PM
mandobizar's Avatar
Default Is Pre-heat hose really necessary to pass Emission Test
Is the Pre-heat hose really necessary to pass Emission? I have to take my 1988 240 Volvo Wagon A/T for the first time here in Phoenix,Az. It's running good, took take of the overheating issue(new radiator, new water pump, new thermo), all fluids changed, getting about 22-24 MPG city(FREEWAY TO JAMMED IN A.M. AND P/M). I noticed my pre heat hose is cut off and connected where is should be. Does anybody know if this could have an affect on the Emission Test? Im going to order it anyway but I need to get the emission done ASAP to get my registration. Thanks
Old Jul 15, 2011 | 03:18 PM
bubba240's Avatar
It shouldn't affect the readings of the test but my fail a visual inspection if they are that strict.
Old Jul 15, 2011 | 04:09 PM
swiftjustice44's Avatar
Exactly. Here in Dallas county, they do a strict visual inspection but really don't know what to look for except missing parts. If they see the heat box on the header pipe missing the hose they could fail you. I simply removed the heat box from the header pipe so nothing appears missing.
Old Jul 15, 2011 | 04:40 PM
if you reconnect that preheat hose make sure the thermostat activated flapper valve thing in the bottom of the airbox is working or permanently jammed shut, or you may end up frying your MAF.
Old Dec 31, 2012 | 05:48 PM
Teamsobaco's Avatar
Jammed shut? As in OPEN to the front for the cold air or jammed shut on the cold air side? It would seem you want it open to where the cooler air is coming from in front of the radiator as opposed to the dryer hose side that goes to the manifold. Is that correct Pierce, jammed shut on the warm side?
BrickMDXLIX
Jul 9, 2012 12:24 PM
VolvoViking
May 1, 2009 06:30 PM
wolfman75
Jun 24, 2008 07:56 PM
belleg
Feb 21, 2008 11:15 PM
ALJOSEPH
Sep 6, 2006 07:01 PM
