What am I driving?
Old Dec 30, 2012 | 06:26 PM
Amat's Avatar
Default What am I driving?
Hey all,
I think I need a history lesson. I recently purchased a 1995 Volvo 940, and it was labelled as a Turbo. It has the original B230FT engine, so I am led to believe that yes, it definitely is a 940 Turbo.
However, on all the other dashboards for 940 Turbos I've seen, there is a needle for the turbo under the tachometer. Mine doesn't have that. It also only says "940" on the back rather than "940 Turbo". Any insights?
Thanks!
Old Dec 30, 2012 | 06:44 PM
the last year or two 940's, they put turbo engines in many cars that weren't branded 'turbo'. I've run into a couple of these. can't say if I know offhand if those would have had the turbo gauge on the dash or not, its also possible your instrument panel was replaced with one from a non-turbo car to fix a bad speed or whatever.
Old Jan 1, 2013 | 07:14 PM
lev's Avatar
lev
'95 940 Turbos don't have turbo gauges, or TURBO badges. '94s have turbo gauges but no turbo badges. Your Air Filter box should say TURBO and be located on the passenger side. Non turbo's is on the driver's side.
Old Jan 1, 2013 | 07:18 PM
Run the VIN and it should pop up as turbo. Also, look under the hood to see if you see a turbo tube.
Old Jan 2, 2013 | 12:29 PM
Amat's Avatar
Awesome, that works out all my confusion. Thanks guys!
timxxx
Dec 21, 2009 01:20 PM
Steamroll9
Feb 16, 2006 11:55 AM
ojala
Jul 3, 2005 04:14 AM
jess176
Jun 21, 2005 04:37 PM
skamil
May 25, 2005 06:54 PM
