Pressure bleeding problem/warning
Old Apr 15, 2011 | 09:48 AM
rickabell's Avatar
Default Pressure bleeding problem/warning
Non ABS '88 240, Put on new master cylinder and was going to pressure bleed. At 20 lbs I heard a pop noise....yep the "american"made reservoir blew open the seam. Now I am afraid to use the old reservoir for the same reason.... back to pump and dump.
Old Apr 16, 2011 | 08:52 PM
swiftjustice44's Avatar
FWIW, you're not the first person that's happened to. It's the little talked about but rather serious drawback of pressure bleeding. Years ago, Snap-On sold a kit that used shop air pressure with a regulator...you can imagine the consequences when the regulator wasn't set properly. Reservoirs are not designed nor built for pressure really, just a reservoir.
taj59
Jul 17, 2014 08:37 AM
bgeacook
Jul 28, 2009 01:40 AM
rene
Dec 7, 2007 01:10 AM
act1292
Nov 21, 2007 08:41 AM
djbaines
Nov 10, 2004 06:43 PM
