pressure bleeding brakes
Old Dec 6, 2007 | 11:41 PM
rene's Avatar
Default pressure bleeding brakes
Hi all. I want to change brake fluid by pressure bleeding for my 86 240 wagon. Does anyone know if there is a particular order I should follow, such as right rear, left rear, left front, right front etc?
Also, I found a simple homemade pressure bleeder using a garden sprayer at http://www.bmw-m.net/TechProc/bleeder.htm
Cheers
Old Dec 6, 2007 | 11:45 PM
tripleb's Avatar
Default RE: pressure bleeding brakes
Start with the furthest and work your way towards the master cylinder.
RR, LR, RF, then LF.
Good Luck!
3B
Old Dec 7, 2007 | 12:02 AM
rene's Avatar
Thanks tripleb. First step is to build the pressure bleeder. I did some searching and found some several sites that preferred pressure bleeding over vacuum bleeding. Cheers
Old Dec 7, 2007 | 12:10 AM
tripleb's Avatar
I agree! I didn't look at your link, but pressure is the way to go. Sounds interesting!
3B
Old Dec 7, 2007 | 01:10 AM
83242GT's Avatar
heads up guys...normal bleeding for all 240s is as follows: Left rear, left front upper inner, right front upper inner, right rear, right front outter*, right front lower inner*, left front outter*, left front lower inner*
*bleed these in pairs (both right then left)....volvos they are picky
macitect
Jun 18, 2009 03:50 PM
jackief288
Jul 21, 2008 08:14 PM
Dalbery
Jul 10, 2007 08:23 PM
Air Defender
Jan 29, 2005 07:45 PM
djbaines
Nov 10, 2004 06:43 PM
