Problems starting?
Old May 2, 2006 | 04:46 AM
tupapison's Avatar
Default Problems starting?
I was wondering whats wrong with my car, usually it's supposed to start when i move my key, but i see myself holding the key for at least 2 second before the car turns on, i know it must be normal for a car this old, but i was just wondering
Old May 2, 2006 | 08:39 PM
Default RE: Problems starting?
When that happens does the engine crank over?
Or you hear nothing?
Old May 2, 2006 | 08:42 PM
tupapison's Avatar
What do you mean by the engine crank over(Im not familiar with that word)?
i just hear like brum....brum..brum(very fast thou, less than 2 seconds) and then it starts, Is this normal?
Old May 3, 2006 | 09:24 PM
tupapison's Avatar
Still waiting for an answer thanks
Old May 3, 2006 | 09:55 PM
Sorry I posted a reply but not sure what happened.
I replied that Since you hear BRUM BRUM it is cranking over(Enigne cranking/spinning over)
Have your Mech. check the fuel pressure and Rest pressure.
Old May 3, 2006 | 10:31 PM
tupapison's Avatar
Check the fuel pressue? and the rest pressure? may i ask whats the Rest pressure?
Old May 4, 2006 | 08:37 PM
The Rest pressure is what the pressure holds at once you turn the car off.
It is supposed to hold for a while and then drop some and then stay at about 15PSI.
If yours is dropping to 0 then when you go to start it you have to push gas all the way from the tank to the engine. That could be why it is taking so long to start.
Old May 4, 2006 | 08:45 PM
tupapison's Avatar
Well is not really taking that long, im talking about 1 and a half second
Old May 4, 2006 | 09:20 PM
Still could be that though. If it is that it will only get worse.
Old May 4, 2006 | 09:54 PM
tupapison's Avatar
k thanks
Old May 5, 2006 | 03:18 AM
tupapison's Avatar
they have a special instrument for this right?
Old May 5, 2006 | 08:31 PM
He should have a Fuel Guage.
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
bccb037
Dec 29, 2004 04:42 PM
rl92821
Feb 1, 2004 12:54 PM
