Puttered to a stop...
Old Jul 21, 2006 | 02:10 AM
mdhughes's Avatar
Default Puttered to a stop...
My 1984 240 DL Wagon puttered to a stop today. It choked up like it was not getting fuel, similar to an out-of-gas situation. Now it will turn over rapidly, but not fire. I have reason to believe it is getting a spark, and I have new plugs and newish fuel pump relay. Should I be looking at the fuel pump next? Are there any easy tests to see if that is working? Would it be possible/safe to check the pump by disconnecting the fuel line on the engine side of the pump, turn the engine over, and see if gas squirts out? Any other glitches that would cause this kind of dilemma?
Thanks,
Matt
Old Jul 21, 2006 | 03:40 PM
billofdurham's Avatar
Default RE: Puttered to a stop...
You should be able to hear the fuel pump humming or feel it vibrating if it is working. It is mounted just in front of the tank.
How long is it since the in-line fuel filter was changed?
Old Jul 22, 2006 | 12:50 AM
How much gas is in it?
Old Jul 24, 2006 | 09:59 PM
wojeepster's Avatar
Check to see if your timing belt broke. If it is not broken check for spark and check for fuel.
Old Jul 27, 2006 | 10:42 PM
VolvoDriver's Avatar
play with the fuel pump fuse? after i had similiar issuse with my '87 244 i had fuel pump(inner) replaced and relay replaced. When it happend again the fuse was moved around and away my tank went.
Captain Zov
Jun 18, 2021 12:01 PM
pnhons
Nov 20, 2011 05:26 PM
panopticon
Apr 20, 2005 02:11 AM
yusufabualamin
Mar 9, 2005 09:40 AM
yusufabualamin
