Questions about 240 before purchasing
Old Apr 24, 2007 | 05:32 PM
Tornadoredcabby's Avatar
Default Questions about 240 before purchasing
Hello
I am considering purchasing a 92 240 Sedan Auto with 130K miles
Anything Volvo specific I should look out for?
Previous owner states that since removing the ABS computer The speedo/ODO only work above 50 MPH, sound right?
Are the 4 speed AT reliable?
The car is in good condition not perfect but looks OK.
New rear muffler and rear pads.
What do you all think is a fair price
Old Apr 25, 2007 | 01:27 AM
montysano's Avatar
Default RE: Questions about 240 before purchasing
Oil leaks are a common warning sign of poor maintenance in 240s. Oil leaks may indicate a lack of maintenance of the PCV system,one of the cheapest and easiest things to maintain on a 240. If someone didn't do this most basic item, what else did they neglect?
Old Apr 25, 2007 | 06:49 PM
Oil leaks? where did that come from?
So no other input
Anyone
Bueller, Bueller............
Old Apr 25, 2007 | 09:48 PM
89_240_DL_Sedan's Avatar
Oil leaks are definately something you want to look at. If the person selling the car says its been well maintained it should not be leaking. The other thing would be to make sure that the overdrive is working consistently. I don't know about the ABS comp speedo thing but it sounds a little strange. Check the brakes out and make sure they work evenly as they should. A 240 with only 130 K that doesnt leak oil should turn out to be a pretty good car.
Old Apr 26, 2007 | 03:44 PM
I too thought that this may be a good car, based on the no leaks, no rust factor
BUT people are telling me the speedo/brakes thing is BAD and I should run ????
Drives good, brakes good, all power and even that works.....
I'm stuck
It would be for my brother and Idont want him to get taken.
Pdxvolvo
Dec 7, 2014 02:40 PM
rickyjones
Nov 15, 2009 10:17 AM
macramer
Sep 1, 2009 07:40 PM
NCS60
Mar 24, 2009 07:04 AM
s1man711
Feb 21, 2006 10:57 AM
