Rear brake lines
The brakes on my '90 240 started making a thump-thump sound when braking. Found that the rear pads were worn. While replacing the pads, I found a stuck caliper - so it has to come off to be rebuilt. Problem is that I couldn't get the brake line off the old caliper. It's stuck in there real good. Since the nut is now rounded off, I need to replace the brake line. However, I can't seem to find any replacement hard brake lines for the rear. FCP seems to stock the fronts but I don't see any for the rear. Anyone out there have a source for this?
I found this site that seems to stock copper-nickel lines of various sizes:
http://www.jegs.com/p/JEGS-Performan...11534/10002/-1
My measurements show the lines to be 3/16" but I don't know what size the fittings are. Anyone use these before? If so, do you know the fitting sizes needed?
I got the old line off. Had to cut it to get the piece out of the caliper. The other end came off surprisingly easy. The caliper end looks like a pretty standard piece but the other end has a female connector rather than a male. I'll check out a few shops tomorrow to see what they could fabricate.
TangoBravoMike
Jun 29, 2010 12:36 PM
Beemer2002
Jan 4, 2010 08:14 PM
mylesfalconer
Aug 20, 2008 12:40 AM
