Rear Brake and Tail Light Problem
Old Jan 5, 2009 | 06:17 PM
jdbs3's Avatar
Default Rear Brake and Tail Light Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1990 240 DL Sedan. My left rear brake and tail lights do not work. At first just the tail light did not work, but it would work every other start up. Now they are both consistently out. I switched the sockets/bulbs to the right side; they work fine. The fuses all look ok. Might this be the printed circuit board? Or? If it is the printed circuit board, can I use an emory board for your nails and clean it off, or something else?
Old Jan 5, 2009 | 06:20 PM
jdbs3's Avatar
Default RE: Please excuse the junk in tghe original post
1990 240 DL Sedan.
Old Jan 5, 2009 | 07:35 PM
Check the printed circuit board and also the plug at the tail light. Also check the plastic at the tail light where the socket goes in.
commoncold
Jul 22, 2014 05:41 PM
motogman
Apr 12, 2012 09:32 AM
enoble
May 29, 2010 03:51 AM
buellfire
Jun 20, 2009 12:37 AM
arie
Jan 21, 2009 06:02 PM
