Rear tail & brake light mystry
Old Apr 11, 2012 | 06:34 PM
motogman's Avatar
Default Rear tail & brake light mystry
90 240 DL sedan. Right tail light and brake light do not work.
I have replaced the bulb failure sensor, checked the fuses, checked the grounds at both the body and the circuit board but no success in getting power to the device. I have checked for voltage at the connector pins and but no voltage.
Any ideas on where to go next?
Old Apr 12, 2012 | 09:32 AM
zjinqui1k's Avatar
These old 240s are somewhat infamous for crappy fuses. Or rather, the fuse box can be some-what perspicacity. Often, even if the fuse is not blown, the contacts can get corroded, and need to be cleaned (ie, sanding). Mine is a 1991, but I notice that the brake lights are on fuse 7, which is also with the ABS. Do you know if you ABS works? If yes, that positively rules out fuses. I have found that anytime I have an electrical problem, the first thing I have to do is be certain it isn't a fuse issue. My experience is that it often is.
88740gle
Nov 13, 2015 08:13 AM
s10lowrider1994
Nov 16, 2014 09:27 PM
commoncold
Jul 22, 2014 05:41 PM
buellfire
Jun 20, 2009 12:37 AM
jdbs3
Jan 5, 2009 07:35 PM
