Removal and replacement of front spindal
Old Apr 7, 2007 | 01:02 PM
reidjw's Avatar
Default Removal and replacement of front spindal
Replaced the front wheel bearings and possibly may have over torqued the castle nut when reinstalling the rotor. Noticed a noise coming from the front left side when driving home from work the next day. A 50 mile round trip. Suspect the spindal may be damaged now because a new bearing will not slide on but the old bearing does. Can anyone tell me how to remove the spindal or if I should try something else before going this far?
Old Apr 7, 2007 | 05:35 PM
TedH's Avatar
Default RE: Removal and replacement of front spindal
try taking a peice of emery cloth and sanding the spindle a little bit to see if you can get the new bering on ive see this work before.
Old Apr 7, 2007 | 10:47 PM
AAER's Avatar
would engine temp. sensor increase mpg on 240??
Old Apr 9, 2007 | 02:32 PM
Kurzweil's Avatar
Default Engine sensors
Probably if the old one is bad. Same is true for the O2 sensor. Those things have to work for the computer to know how much fuel to inject. Emissions reading would tell the tale.
mrvolvos60
Sep 11, 2014 07:39 PM
Volvotastic
Mar 1, 2014 02:54 AM
rolling2
Oct 20, 2010 01:08 AM
58panelvan
Sep 27, 2009 03:09 PM
booyaolian
May 24, 2008 01:37 PM
