removing injectors
Old Sep 5, 2006 | 04:29 PM
charlieruss's Avatar
Default removing injectors
Hi, I have a newbie question. I want to remove the injectors on my 1980 242 dl, my question is do i unscrew them or do they pull straight out? i dont want to just go in there blindly and mess something up...Thanks!
-Charlie
Old Sep 5, 2006 | 08:46 PM
Default RE: removing injectors
Haven't done them in a really long time I think they pull out.
Old Sep 11, 2006 | 10:27 PM
wojeepster's Avatar
unbolt the fuel rail and pull it off, injectors pull straight out sometimes with difficulty. use all new orings and new end caps on injectors use vaseline as a lubricant on new orings. They come in a kit with all orings and cap for one injector. You can get them at fpcgroton.com This is for the later cars 1986,7,8,9,0,91,92 I do not know about the earlier ones.
Old Oct 24, 2007 | 10:30 AM
shwebo's Avatar
Good question, I have the same issue. I have an '81 242 ??? Pull or Screw?
Old Oct 29, 2007 | 01:01 AM
iamnickcarter's Avatar
There's a plastic holder, one bolt retaining the black plastic holder (bolt should be towards the front of the car)
and they pull out with some force..probably a lot of force
The injectors seperate from their fuel lines by unscrewing them at the fitting, 14mm and 12mm
Vmax
Apr 7, 2014 07:42 PM
shwebo
Oct 24, 2007 10:36 AM
cranky
Oct 26, 2005 12:25 AM
240GL38751
Aug 5, 2004 03:25 AM
