rough idle after a few minutes
Old Sep 8, 2010 | 05:53 AM
j1911e's Avatar
Default rough idle after a few minutes
I have a 94 940 non turbo. When I crank the car up it runs fine, then after maybe 5 minutes it starts to run really rough and die. I crank it back up and it does the same thing. I can drive it and it runs fine its just this idle thing i can't figure out. I have replaced the main fuel pump and the intake pump is working. One thing is that i notice the new fuel pump is loud - not sure if this is normal or not. O and the car has 230,000 miles on it. been a good car up to now.
thanks
Old Sep 8, 2010 | 11:53 AM
bigdaddyrdpjr's Avatar
Check fuel pressure regulator, they will do that. I had a 93 240 that did the same thing. Be sweet to the oring when putting it back in.
Old Sep 9, 2010 | 04:51 AM
j1911e's Avatar
Thanks, I replaced the fuel pressure regulator and it is running great.
thanks again
John Ross
Sep 20, 2020 04:04 AM
retired teach
Oct 6, 2012 09:14 PM
Bruno937
Aug 23, 2012 07:52 PM
MaxIcon
Apr 13, 2010 02:21 PM
azhjph
Sep 8, 2009 10:27 PM
