Rough start
Old Sep 13, 2009 | 10:15 PM
dman777's Avatar
Default Rough start
On my 1990 240 Volvo DL non turbo, my car does a rough start only on a hot engine. On cold start there is no problem. The problem is on the rough start is it acts like it wants to die out, and the engine light comes on for a sec...untill I rev the gas. once I rev the gas for a couple of secs the engine runs stable and check eng light goes off. Again, it is only when starting on a hot engine, not a cold start. What could be causeing this?
Here's what I've done in the last 3 months to improve my car and try and fix this problem:
New oxygen sensor
New Flame trap filter
New oil change and filter.
New fuel filter(outside fuel filter)
New spark plugs, wires, and rotor cap.
New air filter.
Old Sep 14, 2009 | 10:46 AM
adub96's Avatar
It could be possible that your cold start injector is coming on when the engine is hot causing it to run mega rich until you hit the gas. Does it smell like gas when you first start the car?
Old Sep 14, 2009 | 02:07 PM
tedv's Avatar
Clean the Idle Control Valve, the big one under the intake manifold: take it out and run some ceaner through it. Also, it could be the Fuel Pressure Regulator-pull the vacuum line and if you smell gas, replace it.
Old Oct 11, 2009 | 08:03 PM
untouchable's Avatar
Check the temperature sensor leads
Old Oct 11, 2009 | 08:04 PM
poirkgic's Avatar
bookmarked and b back l8er, bro, :-)
Old Oct 13, 2009 | 05:33 PM
What does the code read? Sounds like the Idle air control valve.
tdrendel
May 24, 2013 06:36 AM
eplanajr
Nov 13, 2012 06:59 PM
abracadabra
Mar 9, 2012 09:54 AM
T5_AWD_05
Aug 5, 2010 06:04 AM
Carbuff
Nov 29, 2005 09:30 PM
