The Search for a "Radio Code"
I remembered reading something about radio codes and it was Terry's blog. He found the radio code on a sticker inside the glove box. [http://revolvoblog.blogspot.com] He has an older 240 but it might be worth a look.
I had the same problem. Here is what you do, contact your local VOLVO dealer and all you need is a photo id and the cars registration with the VIN# and they will go into there computer and pull it up in about 5 seconds. If your local dealer is far, you can fax them over your id and so on and they will still give you the code. This is all free. Hope you get the radio working!!
p.s. Keep the code in a safe place, because when you disconect the Batt. for any reason you will need to enter it again.
hope i helped.
hope i helped.
I finnaly found the radio code in the old owners manual. Apparently one of the many owners of this fine automobile was smart enough to write it down. That was the last place I ever would have thought of looking for it. It just seemed too easy. Thanks for the help! ~Matthew Hovis
Eviltwin
08-19-2007 10:45 AM
