set ignition timing on B230FT
Old Jan 29, 2009 | 02:01 PM
fredbyte's Avatar
Default set ignition timing on B230FT
Hi everybody,
My ignition timing on my 1987 740 turbo, B230FT, EZ 117K, is ~5 degrees after TDC. The Haynes and Bentley manuals say you can't adjust the ignition timing on EZ 115K and EZ 116K ignition systems. Can you do so for the EZ 117K? This is the overhead cam distributor with Hall sensor near firewall.
If I can't just rotate the distributor housing (which way should I go if I can?), what can I do to get appropriate timing, which is supposed to be 10 degrees before TDC.
Thanks.
Old Jan 29, 2009 | 02:24 PM
You can try moving it but the computer adjusts the overall timing.
Also make sure the crank pulley didn't spin making it look like it is out of time.
Old Jan 29, 2009 | 03:04 PM
TIPSP's Avatar
Got Boost?
Am I understanding this:
I know the computer controlls the timing, but if I were to slap on an Adjustable Cam gear, that the computer would overide it?
Old Jan 29, 2009 | 03:50 PM
No you can adjust the belt but not the Dist. to change timing.
Old Jan 29, 2009 | 03:53 PM
TIPSP's Avatar
Got Boost?
Ok! thanks for the clarification!
Old Jan 29, 2009 | 03:56 PM
Lol np
Old Jan 30, 2009 | 06:02 PM
fredbyte's Avatar
Default EZ 117K timing
Well, I searched some other sites and found out that you can manually adjust the EZ117K. So, I went out this afternoon and loosened the 2 bolts on the distributor and rotated the distributor CCW ~15 degrees. Then I checked timing with timing light and it's right on! 10 deg BTDC.
Old Jan 30, 2009 | 06:17 PM
Thanks for the update. Alot of times it doesn't work you got lucky.
Does it run better now?
Old Feb 1, 2009 | 04:47 PM
fredbyte's Avatar
Default runs better
Runs better after 1 test drive. Hope it stays that way. 3 out of 4 of the spark plug wires were shot, as well. Couldn't get a resistance reading on those 3 on a 20 Mohm multimeter and couldn't get it to light up a timing light on those 3 wires. But the engine did start with those faulty wires and it seemed to run on 3 cylinders rather than one. Strange.
Old Feb 2, 2009 | 04:25 AM
Typhoon's Avatar
Be aware that this won't work on the later engines with the flywheel crank sensor.
Regards, Andrew.
Old Apr 24, 2017 | 01:58 PM
star393's Avatar
Banned
Default ing lets het it right
So you are saying that without hall effect sensor and equipped with flywheel sensor turning distributer will not effect base timing . So When you do move distributer is that changing rotor position as well as cap position or are we missing something and turning distributer will not change rotor phasing with cap????????? Seems like it as nothing changes at crank. So I am 20 degrees ATDC and I have to reposition cam to change timing????
Old Apr 24, 2017 | 03:49 PM
8 year old post.
lh2.2 cars (up to 1988, also 89 turbos), you set the timing via the distributor. LH2.4 cars (89 non-turbos and 90+ anything), its fixed by the computer and crank position sensor, there's no adjustments possible.
Old Apr 26, 2017 | 01:06 AM
star393's Avatar
Banned
Originally Posted by pierce
8 year old post.
So the rotor just can be out of phase then when you move the cap around. so how do you guys phase the rotor correctly?????
put harmonics balancer timing marks to 15 degrees BTDC and pull cap and see if rotor is lined up with # 1 plug ??????
Or what is computer base timing set at.
Old Apr 26, 2017 | 01:09 AM
star393's Avatar
Banned
Google doesn't care if post is 8 years old
Now post is current.
Old Apr 26, 2017 | 01:12 AM
star393's Avatar
Banned
Default keep it coming
does computer use a cranking start ing. timing value and a different idle run timing figure. ??????
Old Apr 26, 2017 | 01:48 AM
the amount of travel in the distributor isn't enough to matter, the rotor will still be close to #1 when its time to fire the spark for #1
The ICU calculated timing is dependent on the coolant temperature, so it changes as the motor warms up.
Old Apr 26, 2017 | 07:47 AM
  #17
star393's Avatar
Banned
Default re
so the base timing is set for 15 degrees ??? upon start up at any temp. ?
To bad NOBODY is smart enough to develop a antifreeze sensor to warn people that the concentration level is below par. But that would cut more business now wouldn't it. But really create more.
Old Aug 5, 2017 | 12:13 PM
  #18
edualdo's Avatar
my 2001 Volvo v70 won't start after timing belt replacement plus no RPM on cranking I need help.
Old Aug 5, 2017 | 12:18 PM
  #19
wrong forum, wrong thread, wrong engine, etc... try the v70 forum here, https://volvoforums.com/forum/2001-2...l-year-v70-55/ and start a NEW thread, don't tag onto the back of an existing one.
USFBull56
Jul 12, 2011 05:56 AM
banjeaux
Jan 13, 2011 12:28 PM
96850urbo
Aug 18, 2009 07:10 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
